- Joined
- 27 Jan 2008
- Messages
- 28,160
- Reaction score
- 3,416
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have made many aerials from simple J using 300Ω ribbon to Yargi beam and HB9CV but in all cases they were for a single band.
I only worked on VHF for many years and when I went to UHF I bought ready made aerials with traps built in so they would work with both bands.
Although I was transmitting as well as receiving you are trying to do something similar, but big difference is getting it wrong will not reflect signal into the set and blow the output stage.
To receive both means the aerial will need a trap so it is seen as to different lengths for the two bands. However since it would seem one is horizontal and the other vertical can't really see how that will work!
The other method is to use a band pass filter to combine and split signals from different bands.
However radio theroy does not always work. I have used a long wire to transmit VHF never mind receive it shouldn't have worked but it did.
Personally can't see the point in DAB it's just a waste of band plan everything is transmitted else where on free view, satellite and internet I use a free to air box the only down side is the display only give a number and I have to connect to TV to find what each number is but once tuned I have far more to choose from than ever I will get with DAB.
OK you have the set clearly the better the aerial the longer the range but as already said start with a paper clip and work up to what works for you.
May be you can design your own cross di-pole aerial for omni-directional vertical is the way to go for one to one horizontal is the way I was surprised to hear VHF is horizontal as in the main I use a car radio with vertical aerial however I have noted aerials built into windscreens which are horizontal however I would have thought signal strength would alter as you turned every corner?
I think DAB was designed for cars but it's been rather a failure in Wales at least can't even get good FM coverage never mind DAB how long it will continue before it is abandoned I don't know I think it will go the way of many more inventions like 8 track, and Betamax they may have been better than cassette and VHS but too expensive and failed.
