US woman was quoted $2400 by environment protection to clean a room after she broke a CFL.
http://www.youtube.com/watch?v=o2S7tV7mTaA&feature=related
I questioned the "Energy saving trust" over use of compact florescent units mainly as to how much energy they saved when the heat supplied from tungsten bulbs is reducing the amount of heat required to be generated from the central heating.
It seems this has never been measured. And because each house will need different amounts of heat input it would be nearly impossible to put a figure on.
It is fairly simple thermodynamics. A 100W is about 2.5% efficient, which means that it is pumping out 97.5W of heat into the room.
No, it's putting 100W of heat into the room. All the light eventually ends up as heat as it gets absorbed by the materials in the room.
But your point is valid, nevertheless.
Although we could consider that energy is never lost but only transformed to another form and as a result the tungsten light bulb only waists energy if the heat produced is not required it is not that simple.
The central heating produces in the mainly convected heat but the light bulb is mainly radiated heat. The latter heats the body rather than the air so it can make one feel comfortable yet the air temperature is still low.
This leaves us with a control problem. If the thermostat is in line of site of the bulb then the bulb will warm it and switch of central heating possible too early and would save a lot of money as it would also heat the body directly without heating air and would encourage one to lower thermostat setting saving even more.
However if the thermostat is not in line of site then the central heating will continue to pump out heat and although it still may encourage one to lower thermostat setting it would require manual intervention for the heat produced to give any saving.
The use of TRV to control temperature means they are very seldom altered and also normally out of direct line of site to be affected by the radiated heat.
Again because of the different form of heating also the amount of air changes in an area will make a huge difference as to advantage and disadvantage of using radiated rather than convected heat.
It is because human intervention, air changes, and method of temperature control make such huge differences as to if the heat from the bulb is useful or not that research has not been carried out to find if they save energy in the home or not. Unless one took a single designed house the results would change that much house to house as to be useless. In houses where the owner has gone silly with lighting using for example 10 GU10 spot lights in a kitchen power wastage is bound to take place.
A few years ago I was involved in lighting some sheds. One was quite high about 20 foot and the low bay 150W discharge lights worked very well. So it was decided to repeat the work in another shed about 10 foot high and it was a failure and they had to be ripped out and replaced with florescent lights. It was plainly not as simple as saying we have x square feet to light so it needs y lumens to light it.
This is also the case with domestic lighting. I remember being instructed to fit 10 x 10w small spots in a room and it looked like a planetarium. Replacing these with a single 100W bulb in centre of room worked fine. Yet both tungsten and both totalled 100W.
We all know white walls are better than dark walls and yet there is no government directive that all internal walls should be painted white.
So to conclude I would say it is impossible to say in general terms if discharge lighting is any better or worst in total energy required than tungsten lighting when used in heated areas. However discharge lighting does produce power factor, and wave form distortion problems and often has nasty metals mercury for discharge and arsenic etc with semi-conductor devices and to encourage the use of these commercial type lights without also doing some education as to the dangers involved must be stopped before it is too late. We have epilepsy and skin problems which cost in both life and general health of those exposed to excessive amounts. Better to use a mixture of all types so non are used in excess.
Better to wait till proper replacements for filament are ready. The light from CF is rubbish
That is correct. Around 7% of electricity in the UK is lost in the transmission network.Electricity is inefficient when distributed over long distances,
It won't be, since there is no such thing.That said the electricity could be coming from a carbon neutral source.
While incandescent lamps do emit radiant heat, the amount is so small as to have no effect on anything. At just 2 metres away from a 100W lamp, the energy reaching the surface is less than 2 watts per square metre.
A typical wall mounted thermostat is around 10x10cm in size, or 0.01 square metres. 0.02 watts of radiant heat is not going to make any difference to any room thermostat or radiator valve.
CFLs are certainly not perfect and they do have some problems.
However, like it or not, incandescent lamps won't be available in the future, and for now, CFLs are a low cost and easy replacement.
By the end of this year, all this will have gone:
- all frosted incandescent lamps (GLS, candle, etc)
- 100W clear incandescent lamps (GLS, candle, etc)
- clear mains voltage halogen lamps 75W and above (such as the 150W / 300W / 500W outside floodlight types)
