You can choose 50:50 or ask a friend
I'm not at all sure that it's in the regs (so goodness knows what answer they are expecting) - but, if one is going to be realistic, the answer should be 'No', if not only because os the existance of 'emergency situations'."is it correct to state that a cut-out fuse may be withdrawn only by a person authorised to do so by the distributor?" Multiple choice answer of YES or NO.
Help which is the correct answer???
50:50 would be a very sensible choice when there were only two answers on offer - but I suspect they would not allow itYou can choose 50:50 or ask a friend
I'm just doing the 1st amendment update on line, the NICEIC/Virtual college offering. You won't believe this but one of the interactive questions asks:
It's pretty resistant - but virtually anything made out of organic chemicals will burn if you get it hot enough in the presence of oxygen.I didn't think that Bakelite burned....
Yep - and all sorts of other things as well; there are more ways to create fire than oxidation!Or other oxidisers
