I have two qoutes which are for similar costs but the tradesmen and taking different approaches for the walls and flooring.
Can anyone advise the pro-s and con-s of each so i can then make my mind up!
The current floor needs raising -
1. Asphalt Flooring (with a DPC) and laminate on top
vs
2. 3 * 2 Tapered Joists & P5 18mm Chipboard with Laminate on top
The Walls need plasterboarding.
1. 1st Tradesmen said if you install cavity wall insulation to the external walls then you dont need insulated plasterboard.
2. Other tradesmen said Fit 2x2" timber to walls and install 2" jablite insulation
Thanks in advance
vs
Thanks in advance
