Without wanting to completely hijack this thread, I have a similar situation and I would like to know if I will get problems...
The outer layer (roof) of my shed is a chipboard-like material, covered in thick roofing felt. I have lined the inside with woolen insulation (the type made from recycled bottles) between the battens and then covered the whole thing with thick polythene sheeting. I have then lined the inside with plasterboard.
Now originally, the top of the shed walls, directly behind the fascias was open by a few inches that allowed airflow right through the shed. This made the shed very cold normally. Where I have lined the inside of the roof, outside you can see where the insulation material now 'blocks up' this void in the roof.
My question is this... will I still have sufficient venting of the roof space through the insulation, thus allowing me to put a soffit in with circular or retangular vents in, or have I effectively created an enclosed space that will now created condensation and begin to rot the roof wood?
Thanks for the reply, and what you say makes sense.
So, should I go ahead and seal in the gap in the shed with a narrow soffit board, and if I do so, should I put vents in because as you say the insulation is now completely filling the void and therefore there is no airflow in/out of the roofspace?
