compression fittings 20 mm to 22mm
17 Feb 2008
i have a 20mm olive which fits on to a old water pipe,
can i use this along with a 22mm straight compression fitting with ptfe tape to make a lasting watertight seal and join up the pipework to enable me to continue with modern metric copper pipe
its possible to use 3/4 olive in a 22 compression fitting....this is more likely your scenario...i've not come across 20mm pipework..(i think anyway)
its probably 3/4 pipe and yes you can use a 3/4 olive and 22mm fitting
edit, I type slow :oops:
well im guessing its a 20 mm as ive tried a olive from a 22 mm fitting which was too big and a 18mm which was to small,
is it best best i ask for a 3/4 olive and try that
