Hi Guys,(and gals!)
Re routing my gas line to my boiler as it was laid in a very unsafe position(an inch from the floor in my garage).
the garage wasnt really being used before so it wasnt such a pending issue.
The pipe that comes into the garage is 1 inch gunbarrell(Iron) and its reduced immediately to half inch copper.
So im going to run it up the wall first and then along so its less likely to get damaged...out of harms way!!
Looking @ the joints on the existing pipework most are soldered but 2 are compression joints.
Id like it to be neat/consistent so im wondering if there is any reason NOT to use either joining method on a copper gas line.
Cheers,
Marty.
Cheers,
Marty.
