Concealed shower not getting hot
4 Apr 2010
Humberside
Is this usually the cartridge on the temperature dial? Does it just stop letting hot water through? Thanks
Check the head or hose isn’t causing a restriction then, if not likely the cartridge. Could also be a failed check valve.
That's the style of shower so they usually have check valves on the hot side? Or must likely the cartridge?
