Hi everyone,
I'm after a bit of help please. I am redecorating a small en suite shower room. There is a back to wall toilet and a concealed cistern. The internals of the cistern were badly damaged by limescale so I decided to replace the internals. I purchased a Fluidmaster fill and flush valve kit to replace the old ball valve type.
I fitted them perfectly however the instructions state the Critical level ark on the inlet valve must be at least an inch above the flush valve overflow pipe. Unfortunately I can only get it about half an inch above due to the work surface above.
Would it be ok if I cut a small amount off the bottom screw thread of the flush valve? This will lower the flush valve slightly giving me that extra half inch needed between critical level ark and overflow pipe.
Can someone let me know if it is ok to do this or perhaps advise me on what I should do.
Thanks in advance
Thanks in advance
