Concerned about shed supply earthing
15 Feb 2007
Derbyshire
Hello again.
At the weekend I decided to fit a new light fitting to the shed to replace an old one which was powered from a socket inside the shed (socket held on with tape and not screwed on) :(
When I took the old light off I found there was no earth - ie cable had just live and neutral wires - so I abandoned the job and took the fuse out the plug to make it safe. To be fair the old light was just an old bulkhead and there was nowhere for an earth wire to connect.
But I'm a bit concerned about the way the shed has been wired up now. It has a consumer unit (hager) which is fed from the consumer unit in the house, and there is wiring to 3 double sockets (one of which the screws have gone rusty), and 2 striplights. The wire used "looks" like the wire used for the old outdoor shed light.
I'm getting an electrician to fit another outdoor light anyway bit I'm thinking of asking him to check the general wiring in the shed. Surely the shed hasn't been wired up with no earth???
R
Who knows...? You're basing that on the fact that the cable 'looks' similar, but are you even 100% sure that the cable used for the light fitting didn't have an earth conductor? It could have been twin + CPC with the bare copper CPC simply stripped back.
Still, it does, one the whole, sound like you may have a bit of a botched installation. We can't see the job, but your electrician will hopefully be able to provide sound advice as he can inspect things properly.
