Concrete blocks - Advice on best cutting method
16 May 2021
Hi everyone,
I’m getting close to laying the blocks for my wall but first I need to cut some of them to size. Can someone tell what the best method is to achieve this? I’ve seen there is a disc cutter or a block splitter or a hammer and masonry chisel. I need to cut around 20 or so blocks so the chisel might be a bit time consuming?
The block size is 440 x 215 x 140.
Any advice would be appreciated.
Thanks,
Ed
No, but I can advise you on better setting out. :cool:
A three brick outer return always works a full block internally with a massive perp (or slithers) or just more inevitable cutting.
It doesn't help that blocks are now noticably smaller than they used to be.
Or two bigger cuts?
Or two bigger cuts?
As I said, just more unavoidable cutting.
The slither method is the most economical - laid internally of course. You would cut your halves as normal then use a slither and then the half or full block up to the jamb.
Concrete blocks dense, for a raised bed.
I used a small angle grinder to score a line on the front and back then a wide cold chisel and a couple of whacks, works well for half and 1/3.
The little bit I had to cut off the end needed a bit more tidying up with a chisel.
Not the quickest but it works for someone with no experience.
Thanks guys. I've decided I'm going with the Hammer and Bolster since I've already got these and I've now watched copious youtube videos. They make it look so easy!
On another note - regarding concrete (which is coming on Thursday) I have a few areas which I've shuttered using plywood. Although not essential I'd like to be able to remove the wood if possible. Can anyone recommend a release agent?
Cheers,
Ed
normally I just use the empty ballast (plastic) bag as a liner and if necessary hit it with a hammer the a day or two later. I'm sure you're supposed to leave it a week or something though
