Thanks Oldun, another comprehensive reply that adds up. The Cut back at both ends of the RC is in the plan so you nailed that one right. Doing the house found first I hadn't thought of but makes sense.thanks we'll do that. The house has a workshop and the overall length to the front is 20m we will go + 3m past one end and + 7m the other for parking plus the cutbacks gets us to 33m, the section covers the house 20m the other 13m will not have the layflat block wall. Most of the stone for the wall will be recycled from the old wall that is there, we have lots of "blue'ies" up here which are pigs to cut (I believe they are hard volcanics from the Borrowdale volcanic group further south which were deposited during the last ice age after being rounded off on their journey) therefore we will alow for 300mm stonework to reduce the cutting, the new wall has to look like drystone walling for planning. Once this 33m section is complete it ties back in to the rest of the stream wall which we are just going to refurbish and add to where necessary. Beefing up the house layflat wall to 300mm again adds up, I think that had to be an oversight on my part as we will need 300mm for the above ground cavity anyway, thanks again for that. Once my SE gets back from holiday I'll cover the actual cavity size for the RC wall with him at the moment he has it at 150mm but it could go 200mm without much cost. Thanks again for you input it has been really helpful.
Tul
Tul
