Good morning,
I'm building a summer house, I've been advised I need a reinforced concrete slab for the base comprising of 150mm thick up to 225mm around the perimeter, ontop there will be two course of facing brickwork incorporating airbricks then the timber frame will built off of the bricks, that's the theory anyway.
How do I insulate the concrete slab, will I have to build a timber suspended floor and use celotex to achieve some form of barrier to the cold slab?
The concept of the airbricks is because I'm assuming I'll need to vent the suspended timber floor.
The reason for the face brickwork is because the vertical cladding has to be minimum 150 from the ground.
The spec for the summer house is 7mtrs x 4mtrs x 2.5 high, it is next to a boundary.
Thank you.
Thank you.
