44 tons is the gross weight of a 6 wheeler artic unit hooked into a tri-axle trailer. I've never seen one as a concrete jaeger, they're usually 6 wheel rigids (gross weight 24 tons), or 8 wheel rigids (gross weight 30 tons).
The type of concrete mixing lorry shown in the images above carries enough material to mix almost 11 cube of concrete. The material alone weighs 27 tonnes! This lorry is not going across a muddy field.
