Tony and his pricing posts should come with a LMFAO warning. It has gone beyond silly now.
I'm starting to worry.
only to discover that the boiler/heating/hot water/ drains/rad(s)/taps/showers don't work!
What does a surveyor actually do these days?
So you would charge a total of £84 inclusive of labour and materials to terminate condense discharge pipe to outside?
Most of us wouldn't buy a car without our own mechanic checking it over!
...what about the fittings required in order to connect condense discharge pipe to waste pipe?...are you presuming a connection has already been made in order for you to come along and pop the condense discharge into it?No, not to the outside which would be more.
But to the inside in 22 mm overflow or flexible tube. At £1.32 for a 3 m length of 22 mm its hardly worth charging for it.
The whole job could often be done in 30 minutes
I only said "probably cost no more than" not that it would always be £84 !
Tony
22mm overflow pipe?..where do you purchase this pipe from?
...as for flexi tube...
Its the location, location and location which matters. Everything else can be changed or replaced.
And we don't know it wasn't a qualified installer either.We don't know that it wasn't a DIYer that did it!
I will agree with that.Its the location, location and location which matters. Everything else can be changed or replaced.
Some people do work ( and survive well financially ) on the basis of having plenty of work at a low rate per hour while others struggle with working (*) less hours per week but with a ( much ) higher rate per hour.You might be surprised at just how cheaply some people work in London.
If a DIYer did something like that
