Anyway you aren't alone. Put it down to freak conditions. Haven't had this problem since condensing came out en mass 5 or so years ago, therefore very freak circumstances which cannot be designed for.
Global warming
Err, no. Freezing temperatures, like the past two years, are normal in winter in the UK. It was the unseasonably warm winter weather that we had for the 5 or so years prior to that which were abnormal.
Water freezes at 0 degC; simples. What is really amazing is the number of simpleton installers and householders who have been surprised by this.
There are a lot of people talking a lot of b@ll@cks here.
The start of this year saw the worst winter conditions for around 50 years and we are now currently experiencing one of the coldest UK winters since records began -
http://www.dailymail.co.uk/news/art...lummet-10C-bringing-travel-chaos-Britain.html - it is almost certain that it will be the coldest December on record - period! I'm no fan of the Daily Mail but they are using scientific data on this one, not just right wing narrow minded hyperbole like most of their articles.
So NO THESE TEMPERATURES ARE NOT NORMAL FOR THE UK, certainly not in the last couple of hundred years.
Secondly if its so plain and simple that water freezes at 0c and this is normal why has the entire gas industy ripped us all off by installing these combi boilers and condensate pipes that will inevitably freeze in our "normal" winters. Having a heating system that discharges water externally into a thin plastic pipe in -10c and expecting it not to freeze is not reasonable, hence these things are actually unfit for purpose, otherwise there wouldn't be so many people experiencing this issue.
The vast majority of condensate pipes are set up like this, not with frost detection systems and so on.
Finally I fail to see how run off would help, icicles form vertically, if its cold enough where the pipe is running then the angle matters not one jot, in fact it is more likely that the water being spread over an incline out will run thinner and therefore lose any heat quicker making it more likely to freeze, when this happens any flow over it will also freeze and ice will build up - also inevitable.
Ice forms at 0c, who gives a toss if it crystalizes at 3 or 4c its -10c outside, whats the purpose of that discussion?
