My boiler is in the loft and during the Beast from the East cold spell I had the condensate pipe freeze causing it to backup and drip through the upstairs landing ceiling. The bathroom is not far from the boiler above hence I was wondering if it viable to run a new 22mm plastic condensate pipe down and connect up with the bath waste pipe? Is there any reason why this is a bad idea? Any do’s and don’ts, such as can I use compression waste fittings for the bath waste connection or are solvent weld ones required? Or would it be better to keep the outside and insulate / trace heat it. The pipe work outside is 5-6m up in the air, around 6” of 22mm plastic inc a 90 bend where it exits the house, a few ft of 32mm plastic and then into a downspout.
Thanks for any advice.
Paul
Paul
