I'm after some advice here! Had a new manufactured slate roof and velux windows fitted 4 years ago. A year later the same builder converted our loft, which is now the main bedroom. I noticed condensation dripping from the felt and asked a different roofer if he has any suggestions on how to get rid of it- this problem is bad in the Winter as there is no heating up there. The roofer said that poor quality roofing felt had been used- it's not breathable. He also said that the only solution is to remove the roof, replace the insulation and felt and then put the roof back on- obviously this is going to cost a lot! My questions are
1. Would it help if there were vents put in? At the moment there aren't any
2. Would it help if we had a couple of radiators put in? No heating up there at present
3. Is there any other cheaper but permanent solution than having the whole roof removed then replaced? He said he could use the same slates so we wouldn't need to pay for more of those.
4. Can we insist the original builder compensate us for not using the proper felt? Should he have asked if we planned on converting the room at some point or just used the breathable felt anyway? Surely the fact we had 3 velux windows fitted at the time should indicate that future conversion was a possibility??? I know the answer to this is no already but it's very annoying!
Any ideas welcomed. Thanks!
