Hi.
You don't ventilate a wark roof because that would alow the heat from the house to escape, thus making it a cold roof!!! A warm roof is installed as follows. Firring pieces are fitted to the joist to creat the falls. Then you board the area in 12mm plywood as your base board. then you cover the base board with a (breathable vaper barrier) not to be confused with underlay! Then you lay kingspan insulation over the area (100mm is more adiquate over living space. Then fit your 18mm plywood decking on top, screwing straight through to the joist below. creating a sandwich affect!! If you have a gap above and below the insulation, the warm roof will be usless. Now when the heat from the house hits the underside of the insulation it is condensing. Because warm air is now hitting a cold surface!!
Venting the roof now may help, but you will loose all the heat from the room below! We have used this method for many years and never had condensation problems with any warm roof we have installed.
If i was you, i would demand my money back and get a proper roofer in who understands how to install roofs!!
Hope this helps??
Cheers RoofDry.
Hope this helps??
Cheers RoofDry.
