Hi all,
I'm a DIY'er and I'm planning on doing the electrics in our new extension myself and then get them signed off.
Because of this I've been familiarising myself with the BS7671 regs before starting the work (starting in just over a weeks time when the screed is dry).
One thing that has confused me is the rules around smoke alarms. I am based in Scotland so, yesterday I bought two smoke alarms and a heat detector (for the kitchen) that are all interlinked and comply with the new regs coming out in Scotland in 2022.
Initially when I read the wiring regs it seemed to say that they should go on their own breaker at the CU but also seems to say that they can run off the same circuit as the lights in the room (which makes sense as a homeowner is more likely to realise their lighting circuit breaker is off than their smoke alarm breaker).
So, first question, am I okay to run the alarms from the lighting circuit in each room?
Next question is around RCD protection. They seemed to (initially) say that the alarm feed should NOT be protected by an RCD. But, then it seems to say that it CAN have an RCD as long as that RCD isn't protected by another RCD ??
Can anyone clarify this for me as the small CU I have for the kitchen/extension is protected by an RCD so, if the requirement is for NO RCD then I may have to upgrade my board
The regs I'm reading are the 17th Ed so not the latest ones so maybe something has changed in the meantime? Just want to make sure I do it right as all this will be getting inspected in the future and don't want to be worrying that there's something not done correctly.
