Confused over new replacement intercom handset
Are you saying ….you can hear the outside when you pick up the phone ? But the caller can’t hear you ?
can’t remember where each wire went on old handset just removed it and then tired to work it out !
I presume that you are in a "Unit" and there are other "Units" which still have the original "handsets" installed.
Is it possible to inspect one of these 'handsets" to see how it is wired and the colours of the wires concerned ?
(However, this may not guarantee that the "handset" in your "unit" was wired in the same way.)
(https://www.intercomsrus.com/intercom_handset_finder_tool.htm has a complete list of all handsets of this type, including your new one
https://www.intercomsrus.com/handse...sic Universal Intercom Handset Data Sheet.pdf
and three models of your old one
https://www.intercomsrus.com/handset pdf/LT 603 Original Intercom Handset Data Sheet.pdf
https://www.intercomsrus.com/handset pdf/LT 603N Beige Intercom Handset Data Sheet.pdf
https://www.intercomsrus.com/handset pdf/LT 603N White Intercom Handset Data Sheet.pdf
but that won't help with the colour code used in the units concerned.)
Each one of the above files contains the following
IMPORTANT NOTE :
1) Before replacing the handset make note of the wires to each terminal on the existing unit (an easy way is to cut each core off leaving a piece of the insulation in place with colour visible) twist unused cores together (so you know they are not used, do not short them out).
2) Some older systems will have cable with one coloured core and a solid white core in this case mark each core with a marker or tape.
3) Some systems may have loop on wiring, you will have 2 cables into your handset (make sure any joins remain, as these may be serving other flats on the system).
Yes I can here outside but can hear anyone speak or they can’t here me speak do you think it is to do with the 3 black wires!
