The reason its below ground and through the wall is because I don't want to trip over the pipe. In any case, he's got the entry angle wrong and needs to lower the up pipe to fit a 90 angle up to the WC pan connector.
The flow is away from the viewer as seen in the photo with drain cover and doorway and runs parallel to the wall, so is in the right direction, I'm just not sure its the correct T for the job.
More to follow... watch this space.
