Connecting aco drain to old clay pipe
5 Dec 2012
I am installing an aco drain to an old clay pipe
It’s quite an awkward angle, is there a flexible 110mm pipe that I can use for such a job to connect the aco to this clay pipe (I’m putting a rubber adaptor on to allow me to connect 110mm pipe to it)
Cheers
Cheers
There are flexible adapters which might mean you have to cut away and replace a length of the existing clay to get tne required wriggle room at the aco connection.
Could bodge with a bit of 4" coil, type used for Land Drains/Service ducting if you can find any, alternatively, cut the clay back enough to allow use of an adjustable bend to get the angle you require.
