Connecting Condensate Pipe To Waste
Why is the bottle trap not good?
As long as it's cleaned regularly then I would say there's nowt wrong with a bottle trap under a sink, especially if space is at a premium. It's also better at catching valuable stuff that may otherwise be lost in a P Trap. P-Trap's are the best for flow of course but there's nowt wrong with a quality bottle trap either IMO.
The clamp you linked to appears to have a rubber gasket for fitting, nothing that would need to be solvent welded?
You're right.. I will look to purchase something similar which can be stuck together with solvent weld.. I just want a joint i can guarantee will be leak free
Well as you can probably garner from my preference for solvent weld fittings, i want something as low maintenance as possible.
So i will consider replacing the bottle for a P trap
Thanks for the help and advice
