Connecting the Outlet pipe to the gas meter
I would give a budgetary quote over the phone for that kind of job.
Don't waste time visiting to quote for small jobs.
If there was anything suspicious then I would ask for photos.
Would usually be £84 plus £14 per metre of 22 mm copper in my local area.
Tony
Tony
Fook me if you lived closer to me I'd contract my work out to you providing your tidy cos your cheap as chips.
Tony
A few 18" walls to drill through would certainly stop you from quoting these ridiculous prices.
.....don't forget the vice as you may have to run the pipework behind soil stack...
A vice would be a bit lumpy to lug around on a bus.
A decent pair of grips would do the same job.
There is another question I have and I admit to knowing nothing about this.
The surveyor who drew up the plan for the new meter position wanted to site it near the boiler which is my only gas appliance and sited it outside through the wall from the boiler.
This isn't near the outlet pipe.
Should it be near the outlet pipe?
They can’t move the outlet pipe can they?
Thanks for help
JamesEB
Outlet pipe is the one that goes to your appliances.
Inlet pipe is the one that brings the gas to your meter from the street
If meter near boiler, do not see any issue connecting outlet to boiler
Disagree..
Squeezing has to be done very carefully and with precision. Vice essential and not every one is capable of carrying out this task:whistle:
Outlet pipe is nowhere near suggested new meter position.
JamesEB
what are the safety reasons they have given ? and where is the existing meter located
Access to services.
The existing meter is not on my property and a way from the house.
The outlet pipe is in my house but not near the proposed new meter location which is outside through the wall from the boiler which is my only gas appliance.
JamesEB
so you have not requested it and its not something that any building work you have done has caused then the entire job should be free from the moving of the meter to connecting of the outlet pipe . This is how national grid would treat it . I would get back onto them
