Connecting toilet
28 Jan 2011
Manchester
Ive just fitted a new bathroom, but the problem is that due to layout - you can see the WC waste connection quite obviously.
I woul like to make it more sightly and considered one of these........
http://www.bathroomz.com/online-sto...eramic-WC-Pan-Connector-330mm-XZ18070010#zoom
But, how does the none wc end connect to a 110 waste pipe? I have a few inches of the 110 waste pipe projecting into the bathroom through the wall. If i use a normal straight connector it looks gash. Just cant work out how these ceramic connectors connect to 110 plastic waste pipe.
The description state that it is a pan connector, so providing they are not telling porkies!
It should just fit like a standard pan connectors does. With one end for spigot and the other for branch/soil pipe.
If you check your link, they have a facility to leave a message if you require more info!
Just paint what you have in whatever colour you choose. That item is plastic not ceramic.
I've found the installation instructions online - sez to use plumbers putty. I've got a normal plastic pan connector (the wickes one from above) but it isn't long enough
