In my garage there's a sink built into a cabinet. It's very handy, but sometimes I get a water leak in the pipes at the bottom of the cabinet. Basically, whoever put this together has just shoved two flexible plastic pipes into each other (the one from the plughole, which goes into the one that goes to the drains). This works fine most of the time, but occasionally they work loose, and then water goes everywhere.
Should I just tape them together with some duct tape, or a waterproof version of duct tape? If so, what sort of tape should I get?
Or is there a better DIY solution?
Or should I just call in a plumber?
(Can put up photos if that will help.)
