If you are connecting up the global tamper, you could do as suggested - I used to do the same with a strip of 2A blocks, taking all the zone cables with a TA loop and connecting 1 tamper conductor from each to 1 from the next, leaving one TA conductor at each end of the loop which connects to the PCB.
You are correct Securespark.
Sorry, and just for completeness, I was looking at the 13v power circuits (not tamper which can be sorted with ins & outs on a normal choc bloc.)
All sorted with links and sharing choc bloc.
