These will not be available for free.
The problem you will have if you do get copies, is that they are not straight forward guides, and contain sentences here and there which have to be linked and interpreted to form the context and meaning
Here are some extracts
BDA Successful Brickwork 2005
2.1
Setting-out the brickwork is different from setting-out the building
OBJECTIVES
One of the main purposes of setting-out facework is to create a matching and balanced appearance of brickwork particularly at the reveals on either side of door and window openings and ends of walls
DESIGN
Broken bond and possibly wasteful cutting can be avoided if the overall length of walls and the widths of doors, window openings and brickwork
between the openings are all multiples of a brick stretcher ...... In practice, this ideal situation seldom occurs and a satisfactory solution is dependent on bricklaying skills
Broken bond can sometimes be avoided by 'tightening' or 'opening' the joints
Broken bond can be avoided by using reverse bond
NHBC 2005
6.1 S2
(b) setting out
When setting out masonry, avoid cutting bricks or blocks except when it is essential and avoid irregular or broken bonds, particularly at openings
(g) bonding
A regular bonding pattern should be maintained
BS 5628-3: 2005
A.4.2.1.3 Horizontal setting out
Anticipate the position of openings, etc. in the starting course prior to carrying out work to avoid unnecessary cutting and adjustment of masonry units at a later stage which can lead to incorrect or uneven bonding (see A.5.1.3)
A.5.1.3.1 Masonry bond
Lay units using a regular masonry bond with nominal 10 mm joints, unless otherwise specified by the designer.
COMMENTARY. It is not practical to vertically align every perpend joint, particularly with bricks having the maximum permissible deviation from the work sizes. For fair faced work it is good practice to align vertically about every fifth cross joint in each course and "even out" the size of intermediate joints. This will give a regular appearance of verticality when viewed from positions other than very close to the wall
2.1
OBJECTIVES
DESIGN
NHBC 2005
6.1 S2
(b) setting out
(g) bonding
BS 5628-3: 2005
