Currently each room's switch is an elderly dimmer. The principle light fitting in the lounge has 5 lamps, each with 40 w. small golf balls. The dining room has a similar fitting with 3 lamps.
I'm considering a change to LED both for the ultimate savings and convenience of less frequent need for replacements.
I realise the dimmers have to be changed, but that done, may I safely mix the old bulbs with new LEDs until the former have failed? Is that worth doing? What rating dimmer is needed for each room?
