built in 1903, with a concrete kitchen floor
may well be under there. What is the floor covered with?
have you looked under any floorboards yet?
Is the hall floor concrete?
Do you have any shrubs or trees that are growing surprisingly well?
I believe there's one on the pavement outside our front gate but apparently we're not allowed to touch it, as there's a chance our supply is shared with that of the neighbours, and damage can be caused when turning the water back on. Seems a bit far fetched to me but the last thing we need is a huge bill from YW for that.
If each has there own stop tap on the boundary, you would be able to see a stop tap cover at each house - have you checked?
No problem at all to reroute see what plumb says.Good point - there is actually an individual stop tap for our house and the one next door, so likelihood is that it's not shared. Looks like we need some kind of tool to operate it though.
The house is tiny - just a living room at the front, stairs in the middle, and kitchen at the back. I've been in the crawl space under the floorboards in the living room and think I've found the water pipe - no sign of a leak at all. Unfortunately the crawl space ends there - it's just a brick wall where the kitchen begins - the pipe appears to go underneath that. I've got a feeling the leak could be at the point where the pipe goes vertical and up to the stop tap, right next to the exterior wall in the kitchen.
I've booked a local plumber with a good reputation to come and have a look tomorrow - possibly an unnecessary expense given that Yorkshire Water are coming in a few days - but the thought of water constantly running into the foundations is keeping me up at night.
Do you think it's possible to cut the pipe at the point before it goes under the concrete and re-route it so it's above ground in the kitchen - possibly boxed in - to avoid having to smash the concrete floor? This would probably be a bit unsightly but having a pipe laid under concrete that risks the foundations seems silly to me.
Thanks all for your help - this is a fantastic resource.
York Water
