Construction and footings for small garden wall (numerous threads merged)
You should remove the layer of top soil or soft ground which tends to be about 250mm.
You could lay a block flat. Otherwise 100 by 250-300mm wide
Hi all,
Looking to make a small wall for a raised bed with concrete block. Wall height is approx 430mm
What size footing would you advise
height x width.
How many 25kg bags of ballast and cement would you say i need for a concrete footing that is
28metres long x 125mm deep x 200mm wide. looking to make a 6 to 1 mix.
thanks
As many as the threads you have started with this some question. Probably
its the first time i asked this question. if your not going to be helpful, please waste your time elsewhere, surely you must have a life outside these forums. thanks
One for the clever clogs out there.
thanks
You need 1.5T of ballast - say 2 grab bags or 60 x 25kg bags, and 10 bags cement. Buying ballast in 25kg bags is an expensive way of buying it!
Thanks I saw that link before. Only seems to work out at 40 bags.
I've been calculating anywhere between 50-75bags so not sure how accurate that is
If you go for the 50-60 bags of ballast (or bulk bag equivalent) and 10 of cement, as suggested by @Charlie George , you should have more than enough to do the job.
It's not as if your usage as footings for a raised bed is as critical as say, the footings for a two storey extension!
You don't need to overthink this! :)
yeah thanks your right pal. im making a mountain out of a mole hill. cheers fellas
thanks buddy. yeah my problem is i dont have any access to the garden, short of bagging it up and carrying it through the house another question, i have lots of old bricks left over i want to get rid of can i just dump into the bottom of my footing and cover over with concrete, would save on concrete and get rid of the bricks in one go.
thanks
Hi All,
I have a number of old bricks i want to get rid of. im in the process of digging out a footing for a raised bed ( only 2 courses high of concrete block) which i will pour 125mm of concrete into, just had a thought, can i dump my old bricks into the footing, would save a bit on concrete and get rid of the bricks.
two birds with one stone as they say. or is this a bad idea
thanks, complete novice here if you haven't noticed.
