Iam wishing to change the consumer unit(s) at home to a more modern setup. I will be using this job as one of my NICEIC assessment jobs for the domestic installer status. Iam currently in the 2nd year of the level2 2330.
Firstly how do i go about legally doing the work, do i still have to notify building control even though NICEIC will be assessing it and i will be able to sign it off once (hopefully) i gain the status.
Also currently the house has the consumer units wired behind a display cupboard which is very difficult to get to, I am wanting to move the unit into the front porch area, iam ok re routing all the circuit cables but what would I do about the meter tails? The cut out is outside in a white enclosure on the garage wall, so would I need to put a fuse isolator in the garage then SWA to the board or, can I run the tails under the floor for the full distance, about 5m
The house has a three phase supply coming in (used to be a small mill), It has 4 old small wylex boards 2 on one phase and 1 on each of the others, 2 boards are used for ceiling heating and storage heaters which are redundant and the other circuits are split across 2 boards / 2 phases.
Would I just take the new board from one phase or would I be able to get the supply changed to SP? I cant see much benefit of keeping the 3 phase supply.
Finally what should I expect from the NICEIC site visit? I presume I will need to supply a certificate & test results, what else will the inspector be wanting to see.
Sorry this is a bit long, Thanks in advance for any help.
Adam
Adam
