Maximum? Minimum might be more accurate.
I wouldn't get much more that that and thats in "wealthy" Surrey and the OP is in the North East
Fair point, but house insurance policies have general clauses about overall Maintenance being kept up, and this would be evidence of that process afaikNo they don't as insurance is on an all risks basis..some may ask for one to lower a premium but they are never required as proof of maintenance, that's just trade misinformation.
What exactly is the definition of maintenance ??? The thing insures want is to see if the homeowner is claiming for observable damage, ie rodents or claiming for a water ingress from a blocked gutter thats been going on for a few years, its stuff that is visible, electrics are not.Fair point, but house insurance policies have general clauses about overall Maintenance being kept up, and this would be evidence of that process afaik
Fair enough, but I thought the market had moved beyond that. Out of interest, how many circuits are you allowing for at that price?I wouldn't get much more that that and thats in "wealthy" Surrey and the OP is in the North East
Dunno, a typic eirc won’t cover all parts of the installation but will be evidence of any works identified as necessary or desirableWhat exactly is the definition of maintenance ??? The thing insures want is to see if the homeowner is claiming for observable damage, ie rodents or claiming for a water ingress from a blocked gutter thats been going on for a few years, its stuff that is visible, electrics are not.
Where I worked maintenance required all screw terminals torqued up, an EICR is only inspection and testing, there is no maintenance as such. On a batching plant in a steel frame as it was portable equipment, yes screws could work loose, but in domestic the whole idea of maintenance free seems a bit off, as we never do any maintenance or service where ever the cable joints are.What exactly is the definition of maintenance ?
Remember RCBO's are the best way to go as if one trips its only that circuit. But a normal 12 way board with 2 RCD main switches + 12 fuses is around £70-£80 with fuses. If you want RCBO's add around £200, So £280.00 + sundries @ £100 = £380.00 + a fair £500 labour for 1 days work £880.00 + possible Vat =£1080.00. So, he is not far off.
I have wondered how far back one can go? Parents house built 1954, 13th Edition did allow no earth to lighting fittings using filament lamps installed in a room having a non-conducting floor, mounted at such a height that they cannot readily be touched and are out of reach of earthed metal. This clearly was not the case with wall lights in the hall, but 13th came out in 1955, and I don't have a copy of the 12th edition, but seems likely the same rules. OK now rewired, but could I have got the builders back to correct the wiring?
So an installation that has no earthing of lights, no RCDs and no main bonding because it was installed prior to bonding being a requirement at the time it was installed would attract a different set of codes for an installation that is is only 1 week old but the wiring and everything else is done to the same standards as the first one ???My view is that providing it met the regs when installed, it's fine, but subject to deterioration.
