Hi guys I got a typical novice question for you.
To mate the 20mm steel conduit with the CU I assume you use flanges on the end of the conduit on the outside of the CU and bushes on the inside.
Since the CU is metal but painted, do you remove the paint around the knockout to get a better earth ?
Also if using the 20mm flanges which have a diameter of 35mm and the 20mm knockouts are spaced 10mm apart (as they are in my CU) then the flange will stick out 7.5mm around the knockout so then I can't use two knockouts next to each other ?
