consumer unit
Damocles said:
Put it this way, you go to a ford garage, you get ford branded parts. You go to a different garage you get cheaper non-branded parts, but quite possibly made by the same company on the same production line.
dont think so, similar yes same, no
timmyquick said:
What seems strange to me is how that having all the circuits protected on the cu by a 30ma RCD is no longer deemed acceptable by the regulations, when surly that is safer than having a 100ma RCD protecting all the circuits on a cu.
the wiring regs don't prohibit a 30ma rcd covering everything but i think other things like fire alarm regs do
the idea is that if there is a fault on one of the cuircuits protected by the 30ma rcd it will trip first before the 100ma time delay unit
timmyquick said:
why was it installed like this in the first place? what is so unsafe about a tt supply that all the cu needs RCD protection?. Unlike modern supplys in new homes?.
TT supplies have a high earth loop impedence which means that not enough current will flow for overcurrent protection devices to disconnect a short to earth
this is why they need some form of rcd protection on everything
Actually, yes. Been quite a few cases where the same parts sub-contractor sells the same thing under an own-brand label. That is the whole point of own brands. Some of these companies are quite proud of their reputation.
That is not to say that there are no rip-off merchants out there happy to sell you brake pads made out of putty.
Time moves on, knowledge changes, safety standards increase..
As plugwash said TT supplies have a high earth loop impedence which means that not enough current will flow for overcurrent protection devices to disconnect a short to earth. See here http://www.diynot.com/forums/viewtopic.php?p=76467#76467 for a discussion of disconnection times.
