Hi, i have an old standard type wylex consumer unit the one with the pull out fuses fixed into the exterior wall. More or less directly behind it on the outside is the electric meter. The cold draft on the inside of my house from the consumer unit is unbelievable and i wondered if i can insulate the holes from the cable routes from the meter to the consumer unit with expanding foam or insulation?
Many thanks
Many thanks
