I don't really get that, given that, as I said, the consumer-provided fuse will commonly be of identical (and presumably always 'similar') rating to the upstream cutout fuse.
To my mind, that means that the only potential advantage to the DNO is that if something happens which blows a fuse (or fuses), then there is a possibility (probably less than 50% probability) that theirs will not blow, so they won't have to attend to replace it.
However, I would think that, even if the 'tails' were very long, it is probably extremely rare that blowing of one (or both) of those fuses has anything to do with something happening to those 'tails' - so that the above argument would apply almost as much when the tails were 12 inches long as when they were 12 metres long - since they only 'require' the additional fuse for tails longer than about 3m.
I also wonder about this 'requiring'. I thought that DNOs had no interest in the meter, let alone anything downstream of it? Do they actually have any authority to dictate what happens downstream of the meter?
Kind Regards, John
