Scum does tend to clump together.He is fully aware of this and like most customers, could not care less.
I moved a CU today for a customer and cut the suppliers seals.
My customer knows I'm not registered but like most normal people he's not bothered, and he knows my criminal activity means the job will get done without waiting for the DNO to do anything, and I'll do a good job. That's all that customers actually care about.
I'm not dishonest. I've never pretended to be registered.
Yes, who gives a toss………until there's a fire, or a fatal accident enquiry? Not your fault, until the insurance company look for a scapegoat. If you are so cocky why are you not registered ?
Never say never![]()
As i have said until something goes wrong. And for the record, just because you tell the customer you're not registered does not diminish your responsibility when it does go wrong. Telling the truth is not your get out of jail card.I moved a CU today for a customer and cut the suppliers seals.
I'm not cocky I'm just telling the truth which seems to be massively lacking on here.
I'm not registered because it does not make financial sense. I only do a couple of notifiable jobs a year and I always explain to the customer before I start that I can't sign the work off. I've never had a customer yet have any issue with this.
True - but, equally, nor does being a member of a self-cert team "diminish your responsibility when it all goes wrong".As i have said until something goes wrong. And for the record, just because you tell the customer you're not registered does not diminish your responsibility when it does go wrong. Telling the truth is not your get out of jail card.
Is that a metal clad one, or a flammable plastic type?Northern Power Grid, my DNO. says it will cost about £104 to fit an isolator switch.
... or a 'non-combustible' plastic type?Is that a metal clad one, or a flammable plastic type?
Fair enough - that sounds fairly 'non-combustible'It's ok; it's asbestos.![]()
