i have a single garage that is set back from the house (not attached)
it is single skin brickwork with pillars at each end and in the middle of each wall. it has a garge door (obviously)
i need to convert it to make extra room desperatly.
the floor is concrete slab. i was gonna put down a layer of dpm and build a shallow raised timber floor so i can add insualtion.
what is the best way of turning the room into a habitable space. i was thinking timber frame as opposed to b.blocks, so i don;t need to add foundations.
also i need to run a soil pipe from one end of the garage to the other , outside and tap into drains. can i chop up the concrete slab just about 150mm width to drop in a 110mm pipe?
thanks matt
thanks matt
