Thanks for clarifying. So it's only 1 or 2 rooms that have only one socket?Hi 2 Bedrooms have one single socket only and another has one single socket on one wall and one single socket on another. However one bedroom that only has one single socket does have a fitted wardrobe on the main wall an I have suspicions that there is a socket outlet behind there (as there is a tv aerial coax within the pelmet of the wardrobe).
That would certainly be the best solution, if you can find a suitable socket. I have certainly seen some in which the terminals are no further apart than those in a single socket.Thanks for the advise as suggested I have been looking at other socket outlets that have terminal connections closer together as this may provide a neater solution.
I would say that would be fine.This had led me to another query (Not sure if this should be a new thread), I have found a double outlet that may work and it also has USB charging outlets. If for any reason I went down the unfused spur route can these type of outlet be used, i.e are they still classed a double socket outlet therby conforming to the one single or one double outlet as an unfused spur?
Kind Regards, John
