Converting to Combi or start again
26 Jun 2023
Problems with a lot of air getting into system, (bleeding radiators every week) sludge, overflow leaks. No plumbers/engineers have been able to fix over many years. Thinking of converting to combi and redoing bathrooms at same time. Would all the floors need lifting in living room, bedrooms and kitchen to install the combi ? They are quite new and wood/laminate.
I think your system needs a thorough flush out, maybe removing the radiators in turn for cleaning if the sludge and gas are as bad as you say.....the two are connected!
The combi can use the same pipe work as a rule, but the pros and cons have been widely discussed on the forum.
It doesn’t matter which heating system you decide upon, if the system is dirty it will come back to haunt.
John
Also converting from gravity feed to pressurised will find leaks. (sometimes)
I have a neighbour who is having that problem now and has to remove the oak flooring to find a leak in a concrete floor.
Andy
The gas that you are bleeding off is actually hydrogen ( largely) that is produced chemically by all the rusty crap that is in there.
You can only solve this by flushing the rubbish out, and then adding an inhibitor to the fresh water that keeps things clean.
The fresh water will eventually deoxygenate and no more gas will be produced.
John
