I'm redoing my kitchen and changing my oven from a single to double oven with a gas hob. I'm also moving it to the other side of the kitchen. The current oven is run from the consumer unit in 6mm cable on its own 32A circuit. The new double oven is 4.3 kw. Can I just join a new 6mm from where the existing CCU is to where the new CCU will be? Or as my current consumer unit has no RCD's in it should I connect an RCD unit to where the old CCU was and then run the 6mm from there to the new CCU? Also for the gas hob ignition shall I connect off the existing ring or the new oven circuit cos if I'm right it only needs to be plugged into a socket with maybe a 3/5amp fuse in the plugtop?
