Afternoon,
I have what I think is a small issue with replacing my current Gas Cooker with electric oven & hob & hood.
The cooker has a wired 13amp plug and the Hob is 6800w.
My issue is that I have a Cooker Switch and 13amp socket next where the cooker is located. So my plan was to connect the Hob to the Cooker circuit and the oven to a spur from the Downstairs ring main. But what should I do for power for the hood.
My only option is to extend the ringmain to add a new socket for the cooker and then take a spur from this to feed the hood
My other slight concern is that the CU seems to only have a 20amp fuse for the cooker circuit and its an old style brown Wylex unit with 6 fuse connections (which are all in use)
1 x 5amp (white) - All Lights
2 x 30amp (red) - Up / Down Ring Main
2 x 15amp (Blue) - Warm air heating / Water heater
1 x 20amp (Yellow) - Cooker..
Any thoughts / suggests gratefully received.
Cheers
Paul
Cheers
Paul
