I am fitting a cooker hood and have thought of options for mains connection;-
1. switched fused connection unit actually on power ring
2. switched 13A socket actually on power ring
3. switched fused connection unit on spur from power ring
4. switched 13A socket on spur from power ring
5. switched fused connection unit on spur from input to cooker switch box, vertically above it
6. switched fused connection unit on spur from output of cooker switch box, vertically above it
My thoughts are that;-
1. requires 2 cables running high up the wall, is probably not allowable and a bit stupid
2. again requires 2 cables running up wall, would mean a power ring main socket would end up a foot below the ceiling and out of conventional ring main zone
3. is probably ok
4. is probably ok also, but requires a plug connection making it seem less dedicated
5. is it allowable?
6. ALL above have problem that the isolating switch is a high reach in an emergency, but this option doesn't, so it seems fine to me, but is it allowable?
I'd like to do 6., but if not allowable what is next best?
3. is probably ok
5. is it allowable?
