I have replaced an old cooker switch and socket - however the new socket will only work when the cooker switch is set to ON. Is this correct and does it depend on the type of switch used because the old socket worked even when cooker switch set to OFF.
you mean you switch the cooker switch off when the cooker is off? we leave ours on all the time, or else the oven looses the time, and its electronically controlled gas so it doesnt like being switched off. if you do the same (leave it on), your problem will cause you no great hardship.
part p wouldn't affect this job. besides, even if it did, so what?
help 'em out if you can, contribute to the forums, continue to joke and mess around. then let the recipient decide whether or not they want to stick to part p.
Check you have the live and neutral from the feed cable going into the L & N in or feed, and the cable from the cooker connected to the L & N out or supply. It is possible you may have got them reversed or mixed up.
