Chances are a 900mm thick stone wall will be rubble filled .
Many thanks, sounds fun, it is Sandstone as most cottages up here in Scotland are built.
If the wall is filled, just go at it from both sides (you need to measure accurately though)
No,or use a long drill to make a pilot hole as a guide ( it may get deflected by a hard stone )
finally some sense.Dismantle the fascia stone (enough to be able to work) carefully and preserve. Hammer out the hole. Pipe through and re-build from the inside out.
finally some sense.
