Core Drilling a 900mm Stone wall
It will be clean
It won't. My company sub-contracts diamond drilling regularly for all sorts of jobs, and a 900mm thick stone wall is unlikely to core cleanly. The chances of loose infill are very very high, and the chances of getting a 110mm core through a 900mm wall and then being able to just poke a pipe through are very very low. You might get lucky, but chances are not.
If the infill drops behind the cutter on it's extension you will have fun!!
Exactly, that is why I suggested the standard tunnel boring method of chasing the drill bit through with a suitable diameter of pipe behind and on the drill's shaft.
Well got the boys in to do it, job was done in 2 hours, with a wet cut dimond core. £200 well spent :)
That was a good price - who did you use? was it just a local company or national?
It was a local Dundee company, can't fault it, turned up at 08:00 this morning, and done by 10:00
Turns out they do this all the time, right equipment and knowhow makes a difference.
