Hi all,
I'm having some trouble working out which 12v transformer I should buy, or if there's even one available for what I want to do, and wondered if anyone was able to shed some light.
I want to install 4 LED spotlights, and 3-4 metres worth of LED striplight in my back yard. The total wattage for everything will be 44 Watts (5w for each spotlight lamp, and 24w for the LED striplight). My question is related to a mixture of LED spotlights and LED striplights on the same transformer. I keep seeing that LED striplights required a 'special' LED transformer/driver, as they usually require the transformer to provide DC directly to the strip light. However, most of the 12v transformers I've seen provide AC, which is then converted to DC by the LED lamps. I also see a lot with the online retailers of LED striplights that they advise to purchase a specific transformer with the strip light, but they don't mention why and if the transformer can be used for other lights too.
So my is there a transformer available that I can wire both LED spotlights and LED striplights in to? Or do most of the transformers out there already allow this, and I'm just being overly cautious? It would be great if I can run all lights off a single transformer, as it'll be a bit inconvenient (although not impossible) to have two separate ones. I can also provide info on what lights I'm looking at buying, I've not actually committed to buying them yet until I know what transformer I need.
Any advice is greatly appreciated, this is my first post so apologies if I'm missing something really obvious.
