- Joined
- 27 Jan 2008
- Messages
- 27,558
- Reaction score
- 3,332
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
It is unlikely humans can see any flicker caused by 50 Hz or more, birds may see it, but not humans. However the whole process is controlled by what is know as switch mode or pulse width modulated output, and there is a minimum and maximum size of pulse and gap between pulses, once the gap is at a minimum next is to switch off, so in essence you start to pulse the pulses as the whole unit switches on and off. This may be seen as flickering but would only happen if under loaded.
